Need help on lining up arrow/triangle lca bushing
After removing the Compliance bushings and cleaning Front Lower Control Arm , I inadvertently removed my paint mark to line up the new bushings before pressing it in. I remember it pointed towards the lower ball joint , but thats all that i can recall. Is there a definitive way to line this up??
Thanks,
Bill
Thanks,
Bill
To be more clear these are Mugen bushings. Your response makes sense however the bushings which were factory installed were not installed like you said with the openings on the sides. They were NOT exactly on the side but were in the approx. 2 o'clock and and 8 o'clock position. In addition there is a yellow dot on one side of the new bushing to which I don't know what it is for?? Unfortunately the directions that came with them are in Japanese.
Imgur: The most awesome images on the Internet
Here I snapped some pics of a stock control arm with stock bushing installed hopefully this gives you a sense of what angle you need to install it in. Next time, use a punch to mark the arm
I wish I took a pic prior to removal....the factory installed mine as I described in my previous post which is different from the pics you posted. Thank you for your time. I'm confused now will wait til Monday and call tech support.
I am well aware and thankful to Slowcrash for his time and effort . It makes sense to position as he has described. I just don' t know if there is any significance to the yellow dot on One Side of the new Mugen Compliance Bushing. Do you?
Unfortunately I don't, but here is a DIY from another member that may help. Good luck.
https://www.s2ki.com/forums/upper-mi...shings-772996/
Thanks for the link, appreciate it. So I looked on google apps for camera translator....Japanese to English....downloaded it.....took pic of Mugen Japnese instructions...which in less than 10 secs. translated the directions to English and nowhere does it describe yellow dot...so I guess there's no purpose.. the interweb amazes me!
killerpenguin21
Jun 13, 2016 02:54 PM
mirabileboy
Sep 2, 2015 10:30 AM
