need help please! (starting/signal wire issue)
Old Jul 8, 2013 | 03:21 AM
donaldmejr's Avatar
Originally Posted by crank
i dnt knw if this helps but the three main relays on the fuse box i swapped the two of them around( i have plastic window no third one for defrost) and also swapped them with the under hood relays.. so i knw there good. im not sure what or where the start cut relay is. i was also intersted in looking at these two plugs to the right of the floor a/c blower vent..i believe one is a PGM-fi unit and the other is just infront of it but not sure what it is. i am not that great with electrical but determined to figure out whats going on !
cabin fuse panel there are 3 relays...center one.
Try plugging the clutch switch first and put a jumper/paper clip between the two wires then see if the starter works.
Old Jul 8, 2013 | 04:21 AM
crank's Avatar
tried that already, still nothn
Old Jul 8, 2013 | 05:14 AM
crank's Avatar
i also noticed there are TWO switches on the clutch pedal, one is closer to the floor, and another is up a bit higher and looks very similar
Old Jul 9, 2013 | 05:30 PM
crank's Avatar
anyone have any advice ?
Old Jul 12, 2013 | 05:51 AM
crank's Avatar
k00leo
Dec 20, 2015 03:43 PM
liquidgsr
Dec 6, 2011 05:16 AM
00S2K01S4
Apr 8, 2006 08:37 PM
Blurter
May 23, 2005 01:38 AM
