need help quick
Old Dec 28, 2007 | 02:40 PM
HondaS's Avatar
Default need help quick
well i was on the way home from work maybe doing 65 cuz of traffic then i get off the freesway and as i come to a stop the car dies. at first i thought i didnt put in the clutch soon enough but when i started it the car sounded like a diesle, like metal tapping metal. so i reved it a little and the rattle went faster till about 4000 then it would go away so im like k ill just pull over into the gas station or somthing but when i started driving it went away completely then i came to a stop and it started doing it again.
so i decided to just drive up the street to my house and it ran fine the whole way didnt tap at all.
also when it was making that sound i could feel the tapping in the clutch petal
any ideas what this could be. when i got home i jacked it up. no leaking oil nothing looked loose like for somthing to be tapping or anything.
im not going to drive it ill take it to the shop but i just wanted to know if anyone had anything similar
Old Dec 28, 2007 | 02:43 PM
HondaS's Avatar
could this be the timing chain tensioner
Old Dec 28, 2007 | 02:51 PM
d5amu3l's Avatar
yea i also think its the auto chain tensioner...ive had that problem with my s2000...its a really easy fix with a diy on the forum...
Old Dec 28, 2007 | 02:54 PM
HondaS's Avatar
is it safe to drive on or should i fix it first.
Old Dec 28, 2007 | 06:12 PM
negcamber's Avatar
You are at higher risk of the chain jumping a tooth on the cam. If you have alternative transportation use it until you get it fixed. Otherwise, don't push the car too much, limit driving, and get it repaired as soon as you get parts.
Hardtop Guy has the part you need.
Old Dec 28, 2007 | 10:28 PM
jyeung528's Avatar
why/how would he feel this in the clutch pedal??
Old Dec 29, 2007 | 08:14 AM
HondaS's Avatar
ya I don't know how I felt it in the clutch felt like someone was under my car tapping smthing with a hammer lightly
edit: also when I pull the part out will I be able to tell if that is what the problem is?
knghtryde
Oct 5, 2013 11:41 AM
Tjs s2k1
Sep 29, 2009 11:59 AM
dab553
Aug 31, 2009 10:43 AM
s2kgeek9
Jul 16, 2005 09:41 PM
traynspotting
Jan 3, 2003 06:24 PM
