Need some help
Old Sep 25, 2009 | 06:17 PM
Tjs s2k1's Avatar
Default Need some help
I had my clutch replaced about 15k miles ago. Ever since I got it, the clutch has chattered really bad during takeoff. Now when im driving at a constant speed (foot barely on gas keeping the speed the same) It hums very loudly. As soon as I have it more gas or let off , it goes away. I decided to check at a stop, I reved it up at idle and I heard a constant grinding noise .. Is there any way to grease the TOB? I cannot afford to take it apart, im a full time college student with no income as of the moment. Let me know what I can do.
Thanks
Old Sep 26, 2009 | 12:03 AM
Tjs s2k1's Avatar
ttt
Old Sep 27, 2009 | 04:46 AM
Fast Jack's Avatar
Bump.Since it chattered from day one,did u take it back to the shop that did the work? What did they say? Constant grinding sound at idle when revved up,clutch in or out?
Old Sep 27, 2009 | 07:19 AM
ronnuke's Avatar
I have heard you can grease the throwout bearing from underneath the car, remove 2 bolts holding on the slave cylinder, and remove the boot from the clutch fork area, then you can reach in there with something like a coat hanger and apply grease to the throwout bearing and clutch fork pivots and contact points. (I was unable to do it this way and had to pull the tranny to replace the throwout bearing and guide to fix my problem which occurred due to using the wrong grease when I installed the new throwout bearing the first time...make sure and use the Super High Temperature Urea grease.) Grease ball end of slave cylinder rod after sanding off any nipple that is being formed on the end of it too while you are at it.....HTH
Old Sep 29, 2009 | 11:59 AM
Tjs s2k1's Avatar
damn, so you were not able to accomplish it by going under the car? I cannot afford to pull my tranny again!
ans2k
Jul 14, 2016 03:58 PM
bewareofthepoop
Mar 21, 2013 11:54 AM
Touge Freak
Jan 23, 2009 06:55 PM
darkwatch
Jul 8, 2007 09:42 PM
CrazyCracker82
Apr 14, 2005 08:39 AM
