need helpe with knock sensor
Old Sep 24, 2010 | 09:49 AM
eddi3's Avatar
Default need helpe with knock sensor
i have a check engine light on becouse of the knock sensor dose that mean their is something bad with the engine? if so what should i do about it
Old Sep 24, 2010 | 05:26 PM
midnightmethane's Avatar
well depends...if you've had your clutch changed there is a high likelihood that they snapped the knock sensor....or maybe it broke by itself but that's pretty unlikely
you just have to get a new knock sensor ($130) and get it installed
Old Sep 24, 2010 | 06:34 PM
s2k dre's Avatar
Or pay 40 bucks for a 03 k20 civic sensor.
Old Sep 25, 2010 | 07:15 AM
eddi3's Avatar
thanks that explains it all i did get a new cluch and fly wheel and thats when the light came on feal beter i was thinking somthing was bad with my motor
Old Sep 25, 2010 | 08:06 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I'd make whoever did the clutch fix your sensor. I think breaking things while doing work on a car is totally unacceptable. Anyone with s2k experience knows about the knock sensor.
They broke it with the extension while working on the upper starter bolt.
Old Sep 25, 2010 | 08:51 AM
zeroptzero's Avatar
Given the higher compression motor used in the S2000 I would think that it would be calibrated differently than lower compression Honda motors but that is just my guess. There might be a resistance test in the shop manual for the sensor, might be a good first step in testing it.
Old Sep 27, 2010 | 12:10 PM
maluch's Avatar
The primary factor while estimating knock frequency is cylinder bore. All the aftermarket detection systems that I have looked at are customized to cylinder bore, or tuned empirically for a specific engine.
The K20 has a bore that is 1mm smaller. This might be enough to upset things...
If the sensors are two different part numbers i wouldn't risk it.
ChorreraS2000
May 23, 2019 04:55 PM
booost02
Mar 3, 2014 08:41 PM
lbodagh
Feb 3, 2014 03:15 PM
s2000turbo
Jan 11, 2004 12:55 PM
