Need to replace front studs
Old Dec 2, 2010 | 03:18 AM
terahertz's Avatar
Default Need to replace front studs
Hi all,
I crossthreaded a lug and would like to replace all my front studs. I know the bearing has to be replaced, but will the hub need to be replaced? that's another $200 for the hubs if so.
From reading, people are saying the hubs can be damaged from bad bearings, but if my bearings are fine, I should be able to reuse my hubs and just replace the studs, correct?
Thank you!
Old Dec 2, 2010 | 04:55 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
your hubs will be fine
Old Dec 2, 2010 | 05:55 AM
flyingtoaster's Avatar
Billman, is is possible that the hub can be spinning inside a locked bearing? This happened to me on a fwd car and I needed to replace the hub.
Old Dec 2, 2010 | 04:47 PM
terahertz's Avatar
Thank you!
SuperKool
Feb 11, 2014 08:32 AM
B.Money
Mar 25, 2011 07:48 AM
GizmoPhoto
May 13, 2010 08:23 PM
FormulaRedline
Jul 25, 2008 09:27 AM
goldenfri
Jul 5, 2006 09:45 AM
