Need some help diagnosing a problem
Old Jul 8, 2009 | 07:02 PM
Adeeos's Avatar
Default Need some help diagnosing a problem
Ok,, While out of town for a month,, My Son took my 2000 out,, It quit on him,, He,, "Says" He drove it home after a short stop,,, Now it spins over,, but acts like there is NO spark,, or NO fuel,, It has fuel,, I sprayed choke cleaner in the TB thinking maybe the fuel pump was out,, and the choke cleaner would at LEAST gimme SOME signs of life,, if so,, I'd start with the fuel pump, etc,, nothing,, I checked the spark on the #1 plug,, it has spark,, it DOES spin over freely with no bad sounds,, etc,, but still just spins, and spins,,, Need to know WHERE to start looking for the problem,,, PLEASE help! Maybe a sensor,, or SOMEthing like that,,,
Old Jul 8, 2009 | 07:10 PM
ahrmike's Avatar
Compression test it. If it doesnt even sound like its catching with starter fluid and it HAS spark...somethings not right/ timing or compression.
Old Jul 8, 2009 | 07:14 PM
Slows2k's Avatar
I hope Jr didn't mechanically over rev the engine and bend all the valves.
Old Jul 8, 2009 | 07:15 PM
Adeeos's Avatar
I'm thinking of pulling the valve cover to check the timing chain,, but 1,, he says he drove it home,, 2, IF the chain broke, I'd "think" there'd be SOME type of sound,, like the chain catching the teeth on the crank,, something,, I'm just trying to avoid pulling parts off to check if I don't need to,,, Thanks,,
Old Jul 8, 2009 | 07:21 PM
Slows2k's Avatar
A compression test is the easiest 1st check.. aqnd you don't have to take the valve cover off.
Old Jul 8, 2009 | 07:37 PM
Adeeos's Avatar
Nevermind... Pulled the plugs,,, #4 is trashed,, .... Thanks,,,
Old Jul 10, 2009 | 11:27 AM
prolux's Avatar
Trashed as in? what happened?
Reminds me of the time i let my girlfriend use my car and one hour when I got it back my clutch needed replacing... "I didn't do anything, I just drove it" hmmmm
blink962
Jun 6, 2013 02:36 AM
s2kjb
Nov 16, 2006 07:06 PM
topekoms
Jul 17, 2006 05:01 AM
VisualEchos
May 22, 2003 05:43 AM
Tugz_S2K
Aug 17, 2002 02:17 PM
