Need some suggestions on my tranny problem...
Old Jun 9, 2001 | 10:52 PM
Phantom's Avatar
Default Need some suggestions on my tranny problem...
For some reason after Honda Gillman put in a new clutch disk, I can't shift into 1st or reverse without applying a lot of force on the shift nob.
I took the car back, and they replaced the flywheel and clutch plate to try to fix the problem. But, it's still the same...I can't get into 1st or reverse without a lot of force on the shift nob.
Anyone know what could be the problem? I want to make some suggestions to Honda Gilman because it seems like they don't know what is wrong...
Thanks a million,
Old Jun 10, 2001 | 03:19 AM
nvmys2k's Avatar
Unicron, sorry to hear that bro. Don't you have other dealerships in Houston that you can take your car to instead of the incompetent Gilman?
Old Jun 10, 2001 | 01:01 PM
Phantom's Avatar
nvmys2k,
Yes, that seems to be the best solution. John Eagle seems to be on everyone's quality list in Houston. I will give them a buzz to find out if they can help me...
Thanks,
Old Jun 11, 2001 | 06:35 AM
Phantom's Avatar
My friend tells me to try bleeding the clutch fluid for bubbles in the line...not a bad suggestion.
I'll do that on my 30,000 mile service this week. I'll let you guys know what happens.
Old Jun 11, 2001 | 06:40 AM
Sev's Avatar
Sev
[QUOTE]Originally posted by Phantom
[B]My friend tells me to try bleeding the clutch fluid for bubbles in the line...not a bad suggestion.
Old Jun 11, 2001 | 07:00 AM
Phantom's Avatar
Sev,
Thanks for the suggestion.
Here is the problem in better detail.
When the car is off, I can shift into gears fine...with or without depressing the clutch.
When the car is on, it's a different story. From a dead stop, I can't shift into 1st or reverse without breaking my wrist on the shift knob. It does seem that when I am rolling at 20 MPH, I can shift into 1st pretty good...it's just the dead stops that I have trouble getting into 1st or reverse.
So do you suggest having them change out the release bearing?
Could bubbles in the fluid for the hydrolic clutch sound like a cause also?
Thanks a million...
Old Jun 11, 2001 | 07:43 AM
Sev's Avatar
Sev
[B]Sev,
Old Jun 13, 2001 | 06:02 PM
Penforhire's Avatar
Is it possible the tranny is spinning down too fast (binding)? That's a standard problem with my other ride (BMW R1200C). Because of some o-rings in the tranny it spins down quickly.
Have you tried double-clutching (rev in Neutral before pushing into first)?
Old Jun 13, 2001 | 07:32 PM
Utah S2K's Avatar
Air in the system....period.
Old Jun 14, 2001 | 04:48 AM
2kturkey's Avatar
..and how do you get it out??? I don't have a workshop manual but suspect my clutch fluid needs bleeding.
