Need some suggestions on my tranny problem...
Old Jun 14, 2001 | 07:53 AM
The Reverend's Avatar
There's a bleed nut on the clutch slave cylinder (look for the only hydrolic line going into your tranny). Bleed it like you would your brakes and make sure to keep the fluid resevoir full (under the hood near your brake fluid resevoir).
I shouldn't have to give this warning, but I've known a few people dumb enough to do this:
DO NOT TRY TO BLEED YOUR CUTCH WITH THE SLAVE CYLINDER OR TRANSMISSION DETACHED FROM THE CAR!!!!!! The little rod with the ball on the end that pushes on your release fork will shoot out like a freakin' bullet.
Old Jun 18, 2001 | 08:38 PM
Phantom's Avatar
All,
I am still in need of some advice...
Since the car is at 30,000 miles anyway...I took it in for the 30,000 mile service and requested them to bleed the clutch.
They did it and the tranny is still the same...I can't get into 1st or reverse when the car has been started. It takes quiet a bit of pressure.
The way I now put the car in gear is that I put the shifter in 1st or reverse before I start the car, and get this...when I release the parking brake, the car starts moving even though my foot is depressing the clutch!
I took it to John Eagle Honda to see if they can help me out...they said "sure", and asked me to bring it back in a couple weeks because they are backed up with flood damaged cars...
Old Jun 19, 2001 | 04:44 AM
Sideways's Avatar
Phantom,
The only thing it can be is the clutch is not disengaging completely. Have you tried to adjust the clutch?? Time to change dealers and talk to the service manager at Eagle.
Old Jun 19, 2001 | 06:33 AM
Sev's Avatar
Sev
[QUOTE]Originally posted by Phantom
[B]All,
Old Jun 19, 2001 | 06:55 AM
cmnsnse's Avatar
Maybe they installed the release bearing backwards, its been a week since I had it in my hand but I thought, unless it comes complete they could screw it up, and make it too short to pull on the pressure plate.
Old Jun 19, 2001 | 02:31 PM
cmnsnse's Avatar
ok nevermind- the throwout bearing seems to be fool proof
what your describing is exactly what happens when a clutch slave cylinder goes bad(leaks), or gets air in the lines
Have you tried pumping the clutch?
Old Jun 20, 2001 | 09:52 PM
Phantom's Avatar
[QUOTE]
Posted by Sev:
No matter what though, don't EVER go back to the dealer who screwed things. What a mess!!!!!!!!
Tjs S2k
Feb 18, 2009 03:17 AM
Goldtrom
Jan 27, 2006 09:57 PM
Dolemike2
Sep 4, 2004 12:47 PM
heffergm
Mar 7, 2004 03:49 PM
Phantom
Jun 9, 2001 10:51 PM
