'new' car maintenance recommendations?
Old Oct 19, 2011 | 12:27 PM
calvinnnnn's Avatar
Default 'new' car maintenance recommendations?
just got an 06 with 34k miles on it and i'm wondering what type of things i should replace now just to be on the safe side of things?
i am already going to schedule something with 00mugens2 to change my diff, brake, and clutch fluids (maybe the engine oil as well).
any other suggestions on what i should get done with the miles it has on it right now? thanks :]
Old Oct 19, 2011 | 12:30 PM
takeshi's Avatar
34K is nothing. Change the fluids (don't forget the transmission) and whatever else needs changing. Check the maintenance schedule.
Old Oct 19, 2011 | 02:20 PM
jh4db536's Avatar
Retorque the rear axle/hubs before it kills your wheel bearings
Grease the clutch pedal pin, slave piston and fork. Check clutch master for leaks?
Check softtop straps?
Sent from my T-Mobile G2 using Tapatalk
Old Oct 19, 2011 | 02:57 PM
spets's Avatar
Change all of the fluids. Engine, Tranny, Diff, Clutch, Brake. (leave the coolant alone, just make sure it's the Honda coolant (blue) and there's enough of it).
Replace engine air filter and cabin filter. Check the Serpentine belt, it may need to be replaced as well.
Check/replace brake pads as needed.
Battery should still be OK. If your cluster doesn't flicker out when you crank the car over, the battery is fine (A little dim is fine, but if you lose the display then it's bad).
Grease the softtop seals with Shin-Etsu grease. Might as well grease the door and trunk seals while you're at it.
Maybe run some injector cleaner through the gas tank (BG 44K for example).
Old Nov 1, 2011 | 11:07 AM
ASIXMRSE's Avatar
http://www.flickr.com/photos/69307271@N05/6302968267/
Word
Old Nov 1, 2011 | 03:07 PM
kolyan2k's Avatar
my 06 with 30k miles needed valve adjustment and coil packs were cracked < so that's what I would check :-) and of course Honda used wrong diff fluid so I changed that as well
Old Nov 9, 2011 | 11:05 AM
Croc's Avatar
mine:
Old Nov 9, 2011 | 12:48 PM
AWDalbert's Avatar
anyone know of a good guideline
how to
or DIY thread for a valve adjustment
http://awdfitted.blogspot.com/
Old Nov 13, 2011 | 01:19 PM
Utah S2K's Avatar
how to
At top of Under the Hood are the blue stickies. Under DIY/FAQ/ Maintain. Go to Engine/ valve adjustment (by Destiny 2002)
Utah
P.S. Is the future start a new thread.....Don't "hijack"
Old Nov 13, 2011 | 03:16 PM
EagleDon's Avatar
Recommend the Owner's manual for service intervals. Then do the obvious (fluid changes, valve adjustments, spark plugs, etc) if others that owned your S2K did not follow the recommended service requirements.
Happy servicing.....
alexz
Jan 16, 2012 12:01 PM
Dog Biscuit
Aug 9, 2010 04:48 AM
intiMACY
53
Sep 24, 2008 06:06 PM
p-p-porkchop
Nov 24, 2007 01:40 PM
AssassinJN
Sep 26, 2006 03:12 PM
