New clutch
Old Nov 26, 2006 | 03:04 PM
DDuds2k's Avatar
Default New clutch
Just replaced the clutch, but the pedal is still really easy to press down. The clutch needed to be replaced but I thought when I did the pedal would get its stiffness back also. Is that a different problem? Is that the pressure plate? Help please
Thankyou
Drew
Old Nov 26, 2006 | 03:05 PM
Ustemuf's Avatar
sounds like you need to rebleed your clutch line, must be some air trapped in there.
Old Nov 26, 2006 | 03:36 PM
Slows2k's Avatar
What kind of clutch was installed?
New OEM pressure plates don't require near as much force as a worn high mileage part.
Old Nov 26, 2006 | 03:50 PM
DDuds2k's Avatar
Um...I actually dont know the specific clutch put in. I think it was one from Honda. How do you bleed the line? thanks
Old Nov 26, 2006 | 03:52 PM
Slows2k's Avatar
If it's an OEM disc the pedal effort won't be much. Go to a dealer and compare your car to a brand new one. If it's the same that's your answer.
There is also no need to open the clutch hydraulic system to install a clutch. Directions on how to bleed are in the FAQ.
Old Nov 26, 2006 | 04:43 PM
DDuds2k's Avatar
cool thanks. I just remember when the car was new, the clutch was more difficult to press, now that it has been around the block a few times (65k miles), the clutch gives pretty easily. I thought with new install, I would have that feel back, but...if it doesnt make much difference, Im not going to mess with it. Ill check out the FAQ on bleeding the clutch...if that doesnt work, Ill let it be. Thanks again.
s2kseven
May 13, 2017 12:07 PM
ebony APWON
Jul 19, 2012 06:11 PM
AZ-S2000
Dec 27, 2011 11:14 PM
zherbo
Mar 13, 2007 07:38 PM
Bass
Mar 5, 2004 09:05 AM
