New Clutch
Old Apr 16, 2007 | 12:46 PM
Sticky2k's Avatar
Default New Clutch
Hi I just recieved my clutch in today and was woundering what all the parts are needed i have the pressure plate, clutch disc release bearing and the pilot bearing. I was woundering if I need the aligment tool thanks.
Old Apr 16, 2007 | 02:16 PM
dbzerk's Avatar
You have all the parts needed.. I didn't use an alignment tool, but then you need a careful eye to make sure the disc is centralized otherwise you'd be there forever trying to get the tranny back on!!
Make sure you use high temp grease on the inside channel of the release bearing!! DONT forget!!
Old Apr 18, 2007 | 04:38 PM
Sticky2k's Avatar
ok thanks also do i need a new gasket is there is one
Old Apr 18, 2007 | 04:40 PM
Reborn56's Avatar
I dont think there is a gasket?
Good luck with it
Marcus
Old Sep 3, 2008 | 04:32 AM
menkio's Avatar
how did you get away with not using the aligment tool?
Old Sep 3, 2008 | 06:53 AM
cdelena's Avatar
You just line up the FD, PP, and bearing with any straight tool or just eyeball it. It is just an aid; all parts will be aligned once the transmission is in regardless.
Old Sep 3, 2008 | 11:07 AM
114_ap2's Avatar
i would get a rear crank seal also
Old Sep 3, 2008 | 05:40 PM
DFWs2k's Avatar
True story, it's definitely easier with an alignment tool, but the transmission isn't really THAT heavy, lol....
Old Sep 3, 2008 | 06:21 PM
TJ01s's Avatar
when it's on your belly you are trying to get the splines lined up, it gets pretty stinkin heavy!
long socket extensions and a good wobble will make your job 1000% easier! esp. with the upper bellhousing and starter bolts
go and get some new subframe bolts, the service manual recomends that they are replaced once you loosen them. I guess there have been a few cases where reused ones have come loose once retorqued.
Old Sep 4, 2008 | 04:57 AM
menkio's Avatar
yea, we used a 3 foot extension for that one upper bolt, a wrench for the side bolts, and that upper starter bolt.. lol we used a wobber extension, and a socket, and lots of cussing. it wasn't too bad, but christ what a dumbass place for a starter..
you want a throw out bearing, and a throw sleeve as well, and yea new subframe bolts are a smart idea.
AZS2KDancer
May 6, 2016 05:46 PM
357MAGNOLE
Mar 30, 2016 04:21 AM
BlackCL
Dec 31, 2014 09:08 PM
joefish1298
Mar 21, 2013 08:08 PM
Boostedtaco
Oct 25, 2007 05:29 AM
