Clutch Replacement parts!
I'm attempting to replace my clutch. And by following the DIY guide, there's a couple of bolts and stuff that could be rounded off and ect...
What parts do i need to buy just incase that are special order? Also besides a clutch, alignment tool, throw out bearing and pilot bearing. Is there anything else i need?
Use hand tools to remove the propeller shaft hex head bolts, not air!! Using air tools here will strip the heads out. If you are good with a wrench you will need nothing else but the clutch kit and grease
Good luck
I have put 7 rear diffs and 2 transmission in my car and never stripped one nut or bolt.
And no I did not blow 6 rears only one
I just finished mine, all I got to say is MAKE SURE YOU JACK UP THE CAR VERY HIGH! Changing the clutch is a PITA. Be sure to have a buddy to help you manhandle that thing back in. Oh yeah, have a swivel and a long extension for the top starter bolt it's not that hard to do just takes time...mine was marked extra red so it was easier to find n aim. Good luck, man.
Been there bought that t-shirt.I was using the only jack on the trans to lower it and didn't have enough clearance to pull it out from under the car.
It's not fun trying to lift a transmission off a jack from under the car so you can pull it out while sitting on a piece of cardboard.
Originally Posted by S2KPUDDYDAD,Oct 25 2007, 08:09 AM
^^^ but, I use a lift
And a little paper man as a helper
I wonder if there's any shops closing down in the area with lifts for sale
coop3422
Apr 3, 2016 04:52 PM
mysterioJR
Aug 27, 2015 03:42 AM
