New coilovers... need alignment?
Old Jul 24, 2014 | 06:37 PM
JohnnyAnonymous's Avatar
Default New coilovers... need alignment?
I read on a WRX forum that a four wheel alignment should be performed after installing new coilovers. How much does it usually cost?
I also plan on upgrading to a new set of wheels and tires from the AP1 wheels I'm currently running once the tires wear out. Would I need to get another alignment after installing the new wheels?
I'm just wondering if it makes more sense to upgrade the coilovers, wheels, and tires all at once.
Thanks
Old Jul 24, 2014 | 07:38 PM
realblag's Avatar
The alignment will not be changed by changing the wheels. If you are planning on running some wider wheels or wheels with a different offset than stock, then an alignment(camber) may be necessary to get the tires/wheels to fit under the wheel arches.
Old Jul 24, 2014 | 09:19 PM
iamatlas's Avatar
Id wait for the wheels if I were you. Plus it gives the coilovers time to settle so you can get the ride height set. Get the ride height set before getting the alignment because change in ride height equals change in camber.
Old Jul 25, 2014 | 06:36 AM
vtec9's Avatar
Yes, 4 wheel alignment after coilover install.
1) install coilovers
2) set ride height
3) drive several hundred miles over the span of 1-2 weeks
4) get 4 wheel alignment
5) pay $120-200, depending on the shop
Old Jul 25, 2014 | 07:11 AM
Thanks for the replies everyone.
jst2878
Oct 23, 2012 11:56 AM
Turn-R-Us
Aug 27, 2007 11:23 AM
specialk22tt
Nov 11, 2006 06:15 PM
ApexMotorPro
Apr 26, 2006 11:15 PM
