New Motor Mounts, then running rough
have a 'built' f20, supercharged running on aem infinity.
I've just replaced my tired Ballade motor mounts with Innovative Race Mounts using a much higher durometer rating (85A). not solid though.
the very next time the car was started the motor acted as if it had limited fuel or only 2-3 cylinders. 6-8 seconds later it 'snapped out of it' as the AEM began its 'O2' idle sequence.
however, the car ran rough around town under harder acceleration, and totally choked under 75-85% throttle.
Anyone suspect this could be Knock Sensor related?
I have read a couple of threads in the past with people developing an issue like this who happened to have race mounts but have not seen an instance where the issue follwed immediately after the mount install. This makes me think that is definitely the issue, but wanted get experience/inout before diving in too deep.
If it was a knock issue, what options for a solution do i have?
If it is knock related it should be easy to check in the AEM software, as a temporary test you could just disable the knock sensor.
I'm not that familiar with the AEM software but I'm sure there are others here that could walk you through it if you are unsure.
