New Tires and Alignment Issue?
Old Aug 30, 2009 | 08:25 PM
si2ik's Avatar
Default New Tires and Alignment Issue?
I recently got new front tires for my S and after driving it for like 200 miles my alignment seems to be messed up. The car now steers to the right if i hold the steering wheel straight. The new tires are Falken Sincera and i have Bridgestone Potenzas S03 in the rear. they pumped the fronts around 35psi. Does this usually happen when you mix and match tires? Do i need to get an alignment? or maybe decrease the tire pressure? Thanks
Old Aug 30, 2009 | 08:47 PM
macr88's Avatar
Swap the front tires and see if it pulls the other way. If it does then one of the tires is defective.
Old Aug 31, 2009 | 09:13 AM
jeffbrig's Avatar
My money's on bad tires. Not a fan of Falken quality.
Tried a set on the TL, had the exact same problem. Moved the tires all around, had the car on the alignment rack 3 times, never could get it to stop pulling one way or the other. Eventually the tire shop swapped me out for a different set of tires - now it's perfect.
Old Sep 2, 2009 | 10:30 AM
Kyushin's Avatar
Banned
I miss the S03 tires....
RMIC
Apr 1, 2023 12:31 PM
JLUDE
Oct 24, 2011 02:15 PM
hylysly
Apr 28, 2006 09:22 AM
xtinkt
Aug 13, 2005 05:59 AM
scs2000
Aug 11, 2005 09:08 AM
