"New" trans already grinding
Hey guys, less than a week ago I put in a competition stage 2 clutch and a transmission I bought from the previous owner of my car. He said it had around 30k miles on it. Installation was a b*tch but it's in. When I carry 2nd gear out to red line and try to shift to 3rd it grinds pretty bad and I need to wait a second to put it in. Do you guys think he screwed me and gave me a bad trans or what? I have an AP1 btw. 78K miles on it
Does it grind much at all when you don't quite redline? Even when I drive the ap1 spiritedly and go into vtec, I don't typically go all the way up to 9k., maybe 8. If it is only grinding when you are at full throttle while ringing it out fully to redline it is quite possible the previous owner wasn't even aware if he didn't regularly redline the car. Just a thought, odds are less than 50/50 that he knowingly screwed you. Though I don't know the seller and I can't tell how bad it is grinding, under what exact circumstances (other than what you described at redline).
Other guy greased it up for me but the splines were greased and that's about it, I don't have any real power adders just the basic intake and exhaust. And I went with the stage 2 as I wanted a harder catch as I plan to turbo sometime in the future.
But, another thought. How long did you drive to break in the new clutch?
Initially the disk will not be perfectly flat, so there can be very slight high spots that could cause some drag, which is similar to clutch not fully releasing, and also cause grinds. If you didnt drive nice and easy for like 500 miles or so, not all highway, plenty of gentle clutch engagements to wear the disk flat, this could be your issue.
Sent from my SM-G920P using IB AutoGroup
It may be the clutch then, as I have put 300 miles on it but most are highway miles. Would this lead it to just grind for 2nd to 3rd though?
