Newbie: Just bought my 02' s2k BUT...
#61
uPaDaTe: MISFIRE ISSUE FIXED!!! WOOOOO!!!! Turns out i had to order and install 4 new coil packs (AP2 backwards compatible version). Put those in and plugged in my newly purchased OBD-II (bluetooth), cleared the misfire codes, and voila! no more misfire!
BUT NOW A NEW CODE POPPED UP saying my IAC valve is causing problems!
I have already taken it off and cleaned it, but i think i need to clean it more thoroughly this next time. I'm hoping its not a wiring issue because i have no idea how to read any sort of diagnostic machine for measuring electric currents.
Hopefully after i do this i will have solved all my little engine gremlins (wishful thinking)
#62
OMG, SUCH A NEWB MISTAKE!!! I can't believe I didn't check the cabin air filter! That thing was absolutely disgusting *barf* so clogged up with hair, lint, dirt, and debris that it turned black! I cleaned it out and re-installed, now the car seems like it's finally running smooth, and the IAC error code went away! I'm surprised the Dam car even started with how bad this air filter was *facepalm*
Does anyone have suggestions as to which brand air filter I should buy? Carbon activated? Price?
7-20-16: looks like the idle fluctuation issue is back when I started it up this morning :'( maybe need to clean out another filter...
#63
#66
Well apparently I have either a short ram air intake or a PRM air intake. No heat shield or box. I have no idea how to clean the internal filter of this thing. I've Google and looked at multiple forums. Nobody knows to to clean this intake filter.
#67
finally got around to replacing the adjustable lower ball joints (P1 buddy club $400) and got the car off the jack stands!
PROBLEM: this actually had the opposite impact i wanted. I thought it would give my tires MORE clearance from the fender wells, BUT it actually gave me LESS clearance! :'(
Now every time i take a slight turn or go over a small curb, my tires rub the wheel wells... sigh... I'm asking a buddy to sell me his stock AP1 front springs so i can install them.
Also, I'm still having idle issues; it's definately the IACV. After all the money I've dumped into fixing this thing up; what's another $200 am i right *rolls eyes*
progress is looking good. After i get my iacv replaced i think it will finally be running smooth. *crosses fingers*
#68
I enjoy reading about your journey with the S2k. You might find that you can learn a lot working with a friend on your car or other cars. My first experience was helping a friend pull, rebuild, and reinstall the engine in a Toyota Landcruiser around 1974 or so. I learned a lot on that project.
#69
#70
i think some good advice is if there was someone there to help you check your work.
everyone was a beginner at some point, and it seems that you are a beginner, and for that reason someone should be checking your work.
good luck.
good luck.
