Nitrous -- more power before Vtec?
Old Feb 25, 2010 | 05:51 AM
  #21
1999's Avatar
great set up. Sounds like you tapped into your existing fuel lines for the fuel source. I am contemplating doing the same thing you have done but running a seperate fuel source then you could mix 110 or even 114 with the nitrous. My mechanic said turbos and sc love nitrous done right because of the cooling effect to the intake charge.
Old Feb 25, 2010 | 06:15 AM
  #22
JuicedS2K's Avatar
H ondas
O n
N itrous
D estroy
A nything
Old Mar 18, 2010 | 02:42 PM
  #23
CJB22's Avatar
So i'm just wondering... ive got a wet zex setup and i placed the fogger nozzle about 10 inches away from the throttle body. Should it be any closer? I've heard that 6 inches is the best from some guys with kits on civics but i dont know if thats the case for the 2000s. Thanks ahead for the advice. The car is otherwise N/A also.
Old Mar 18, 2010 | 02:57 PM
  #24
JuicedS2K's Avatar
10 inches is fine. just make sure if its 10 inches away that that part of the intake is basically level with the throttle body, sometimes all the fuel doesn't make it up the length of the intake if it has to travel upward.
Deleted03.15
Sep 22, 2017 12:59 PM
E4RTH WORM JIM
Nov 15, 2012 01:31 PM
wrxrick
Sep 14, 2005 10:08 AM
Liemoanh
Aug 30, 2004 05:17 PM
