Nitrous Oxide Systems
Old Oct 15, 2002 | 05:10 PM
SC-SUZUKA's Avatar
Default Nitrous Oxide Systems
Does anyone have a Nitrous Oxide System on their S2000? If so, is the system wet,dry,direct? does anyone have pics also.
Old Oct 17, 2002 | 07:27 AM
HARDtoTOP's Avatar
There is a recent thread on this. If you scroll down you will see pics of my set up:
https://www.s2ki.com/forums/showthread.php?...&threadid=86045
Jeff
Old Oct 17, 2002 | 07:48 AM
3rdgenrx7's Avatar
zex works the best. that purple box works magic
i suggest a fuel pump upgrade. the stock injectors will be fine.
Old Oct 17, 2002 | 01:15 PM
laika182's Avatar
Nos can be used safely as long as you use an equal or less than shot than your stock horsepower. For example on an integra type r which has 200hp, it is best to use a 100 shot or less on it to ensure the life of your engine. I would also recommend using a wet shot because you get the torque as well as the horsepower.
Old Oct 17, 2002 | 02:53 PM
iLikeBeer's Avatar
[QUOTE]Originally posted by laika182
[B]Nos can be used safely as long as you use an equal or less than shot than your stock horsepower.
Old Oct 17, 2002 | 09:08 PM
supwithyou's Avatar
In reply to the above, can you say Kaboom?
Old Oct 17, 2002 | 10:28 PM
Fanman's Avatar
In reading the NOS literature I think they said 60 shot or below for 4 cyl., and 100 shot or below for V-6's.
Old Oct 18, 2002 | 03:09 PM
GSRacer's Avatar
Originally posted by iLikeBeer
100 shot on an Integra
oh yeah, i had 100 shot on my intergra gsr before i installed the turbo. actually the integra is better than the s2k to do a 100 shot, cause you can retard the timing.
Old Oct 21, 2002 | 05:41 AM
LordMagnet's Avatar
60 shot should be the "safe" max, unless you start replacing parts with aftermarket that could handle the extra nitrous.
Old Oct 22, 2002 | 12:12 AM
honda9krpm's Avatar
How long does the S2000 nitrous powered take to get to 60mph?
blazins2
Jul 29, 2013 06:48 PM
Chaos Performance
35
Feb 7, 2012 09:08 AM
Dark
Jul 29, 2008 10:01 AM
VtecSpool
May 8, 2008 10:48 AM
Eze8199
Jun 24, 2001 06:53 PM
