no #3 injector pulse. HELP
Old Dec 14, 2010 | 06:27 PM
s2kevan's Avatar
Default no #3 injector pulse. HELP
-Im running AEM EMS on my 2002 vortec supercharged s2000. just recently rebuilt it and only started/drove it a few times. It sounded like it had a miss so i hooked up the laptop to see what it was doing (I have no tuning experience, i was just curious).
-I came to find out the the EMS was not registering any injector pulse for #3 injector.
i have switched the injector over to another cylinder but it still reads no good for #3. -Am I simply looking at a faulty wiring issue?? any advice helps
Old Dec 14, 2010 | 06:50 PM
suzawadc2's Avatar
2 wire circuit. one power wire and one ground wire. you should have power on one with the key in the on position. the other wire is where the ecu pulses the ground (transistor). check the ground side with vehicle running.
backtrack from there. hopefully you have or have access to a wiring diagram for the injector circuit.
if you have no power at the injector connector, there is an open somewhere. look from the injector to the fuse box and whatever connector in between.
if no ground, there's an open in the injector ground ckt. ecu transistor is not grounding ckt. or open in the wiring or connector
Old Dec 15, 2010 | 07:19 AM
s2kevan's Avatar
ive got power to the injector with key on...havent checked it yet for ground pulse...will do that and repost asap
Old Dec 15, 2010 | 03:41 PM
AusS2000's Avatar
I'm guessing you're using a 1012.
If so, you need to use injectors 1,2,4,5.
Don't ask me why. Just the way it is.
Old Dec 16, 2010 | 06:08 PM
suzawadc2's Avatar
preferably, you check the injector with a noid light since the injector pulse is very rapid. it's harder to see the pulse with a test light as compared to a noid light.
Old Dec 17, 2010 | 06:28 AM
s2kevan's Avatar
auss2000..........are you talking about my version EMS? i think it is the first generation. silver case. are you saying on this version its supposed to skip #3 injector???????
Old Dec 17, 2010 | 10:24 AM
AusS2000's Avatar
Yup.
Old Dec 20, 2010 | 05:25 AM
s2kevan's Avatar
well ill be damned. guess that answers that. thanks alot. now the bitch wont start. kinda looking for some startup parameters now
deuce_s2k
Jul 5, 2015 05:58 PM
Ap2low
Jan 15, 2015 05:10 PM
biohazarde
Jan 19, 2014 09:12 AM
ap1tuner
Jul 6, 2010 06:07 PM
siadam
Jul 3, 2010 08:59 AM
