no compression across all 4 cylinders
Old Nov 18, 2009 | 02:55 PM
Kado413's Avatar
Originally Posted by wadzii,Nov 18 2009, 03:51 PM
my aem was doing that.. it didnt want to restart on a warm start up if it died. i replaced 2 resistors and all was good.
but you should have ~150-180psi i think.. its been a while since i have done a compression test on a s2k w/a thick hg.
but with 90 and 50.. its time for a rebuild, no since in speculating. its got to come apart to fix
where should I start on the rebuild? the head (valves) or the block (rings, pistons)???
just trying to do it the most money conserving way..
the mechanics are baffled since its 80% across all cylinders and dont hear the air coming out =/
I was assuming it was the rings
Kado413's Avatar
I APPRECIATE ALL THE HELP!!!!!!
Old Nov 18, 2009 | 03:16 PM
wadzii's Avatar
Banned
the mechanics should know where to go from here..
id start by pulling the head and going from there.
Old Nov 18, 2009 | 03:38 PM
Kado413's Avatar
alright....thanks!!
Old Nov 18, 2009 | 04:03 PM
turbo_slug's Avatar
80% leakage should result in lots of air noise...i assume someone closed the valves before making measurements?
Old Nov 18, 2009 | 04:08 PM
Kado413's Avatar
yeah, they put it to tdc and did each cylinder...we didnt hear any air..thats what has them baffled =/
I spoke to another mechanic and he was saying maybe the valve guides are bad and the head is in need of a valve job...and he was saying if there was this much leakage the car should not run..
Old Nov 18, 2009 | 04:28 PM
wadzii's Avatar
Banned
have them pull the cams out then do the leak down test.
Old Nov 18, 2009 | 04:44 PM
Kado413's Avatar
I have an appointment on Monday at another spot...
Im thinking I should just rebuild the head already and save some time....
Old Nov 18, 2009 | 04:50 PM
wadzii's Avatar
Banned
they have to pull the cams to pull the head, may as well take 5 mins and do a quick leakdown
Old Nov 18, 2009 | 04:53 PM
Kado413's Avatar
cause that will tell me for sure if the valves are bad???
