No more clutch =/
No more clutch =/
So I'm guessing, but I'm pretty sure the clutch died on me yesterday while rolling through town. When I push the clutch it just goes straight to the floor. I had to limp her home floating gears ><
your cmc could be leaking, or the slave/cmc itself went bad.
I don't think a bad clutch disc would give the pedal a feeling of zero tension and have it go straight to the floor. Sounds like hydraulic pressure is an issue.
Thanks, I was thoughtless before posting that.
I remember a few weeks ago I was having issues with it shifting, so I checked the fluid and it was low as hell.....so I am about to go out and bleed the system to see if I hit a air pocket. I'll keep ya posted on the progress.
Having pressure in the pedal isn't a clutch disc issue from what I can remember. it's most likely the hydraulics or MC/SC. not sure if the S is using a cable too but in the mustang 99-04 they used a cable and the cable snapping was a viable possibility.
I seen a cable of some sorts when I was under there, I'll jack it up a bit more and try to trace it to see if there's a snag or break in the line.
If it is leaking, replace BOTH the cmc and slave for good measure.
Are you sure you bled all the air out of the clutch slave cylinder?
My clutch master cylinder was leaking at the piston behind the pedal. (I've seen posts saying is normal, just change the clutch fluid every few thousand miles.) But I left it unchecked for over a year, and had almost no fluid left. I had to pump the pedal several times to build up enough pressure before each shift, just to get home.
I ended up unbolting the slave so i could point the bleeder straight up to get all the air out. Pedal felt great after that.
