No SRS light
Old Dec 21, 2006 | 09:53 AM
S_3000's Avatar
Default No SRS light
Recently purchased S2000. Needs brake and light inspection Previous owner said it failed due to an airbag light. I cant seem to see any light. Should it illuminate when the car is started then go out like all the others? Could the bulb have burned out? Any help is appreciated.
Old Dec 21, 2006 | 06:47 PM
Slows2k's Avatar
The SRS light should come on when the key is 1st turned to on, it will go out of no faults are detected. Chances are the bulb was removed instead of fixing the problem. It's all to common on the used car market.
Old Dec 21, 2006 | 09:06 PM
SilverDC2 AP1's Avatar
you should have it checked out, some local shop did a bypass once on my parents blazer. =/
Old Dec 26, 2006 | 06:03 AM
S_3000's Avatar
Thanks for the advice. After close inspection, I discovered the bulb assembly to be there with NO bulb in it! Idoits! I attempted to reset the srs but its still on. What next? Should I go have codes pulled in order to pinpoint the problem or does someone have any advice? Thanks again Slows2k
Old Dec 27, 2006 | 03:12 PM
Slows2k's Avatar
You need the stored SRS code before you can go any further.
Old Dec 27, 2006 | 05:50 PM
viper_driver's Avatar
S_3000,
Once you get the light working, you can put a jumper across the plug under the passenger dash and read the SRS DTC code on startup and see what's wrong.
Do you have a repair manual?
I'm working a similar problem on my car. Turns out the SRS unit is bad and the stealership wants $1000 to fix it. I just bought a new SRS ecu today out of a wreck for $100. My guess is that's what's wrong with yours, but you may have to take it in the dealer to get it checked out first. The airbags are about 5-600 each. good luck,
JASON
Holeshot121
Sep 11, 2021 12:17 PM
skunkster
Jul 23, 2007 08:38 PM
if lookz kill
Nov 29, 2006 04:06 PM
S2drag
Feb 10, 2004 10:53 PM
