Is it normal for Maint Reqd light to flash 10 times when key turned on?
Old Sep 17, 2001 | 07:39 PM
nefarium's Avatar
Default Is it normal for Maint Reqd light to flash 10 times when key turned on?
Is it normal for Maint Reqd light to flash 10 times when key is turned on?
Yep, that's my question.
I noticed it right at 5995 miles, five mos old.
The light doesn't stay on when driving though.
I just had it into the shop to have the rear left strut replaced, as it was making a bad "knocking" sounds when I hit any bumps. The guy at the dealership said that sometimes the struts have a bad valve in them.
Thanks,
-Chris
Old Sep 17, 2001 | 07:49 PM
Rowland's Avatar
Yes it is normal.
It is supose to remind you to change your oil more or less. If you change your own oil and do your own maintenance then you will have to do it yourself. The instructions are in your owners manual, it is a simple procedure.
I believe it will flash before your scheduled maintenance is due (so many miles before???) and then once it gets to the mileage that your maintenance is due it will remain lit until reset.
Sorry, I do not have the correct mileage for you, my manual is in my S2000.
Old Sep 17, 2001 | 08:51 PM
Da Chronic's Avatar
The manual should tell u how to reset the light. ITS NORMAL. If it still does that after reseting it, DESTROY the defective S2000.
Old Sep 18, 2001 | 12:12 AM
Schatten's Avatar
change your oil / have someone change it, and then check out this faq on resetting the maintenance light.
Old Sep 18, 2001 | 02:28 AM
CoralDoc's Avatar
The MAINT REQ light will flash at 6,000 miles and come on steady at 7,500 after being reset.
Please be aware that the procedure from the owners manual (p 49) does not work in my MY 2000 S 2000. The slightly modified procedure, as specified in our boards FAQ does work. https://www.s2ki.com/faqs/showfaq.php?threadid=17415
1. Insert the key into the ignition (do not turn it).
2. Press and hold the trip reset button
3. While holding the trip reset button down, turn the ignition to the 2nd position (dash lights come on).
4. Continue to hold the trip reset button until the MAINT REQ light goes out (this may take 10-15 seconds).
That's it!
AP1Driver
Jul 16, 2023 06:26 PM
blobianco
Jan 24, 2011 10:03 AM
S2KBLanton
Mar 4, 2008 02:38 AM
trivium
Feb 21, 2007 04:03 AM
hyperpm
Jul 17, 2002 09:50 AM
