Not able to shift into 6th
Old Mar 22, 2015 | 10:16 AM
AA56's Avatar
Default Not able to shift into 6th
I missed a shift and now I can only shift into gears 1-5 and reverse. I suspect the bushings on the shift linkage but I typically only work with engine projects.
Anyone ever have any ideas to trouble shoot the transmission problem???
Old Mar 22, 2015 | 10:37 AM
notaloafer's Avatar
I did the famous misshift gear grind myself once too. I've seen numerous other people on the forum do the exact same thing. Billman, correct me if I'm wrong, but all you need to do is force it into gear. Work by throwing the shifter from 5th to 6th with pressure. Eventually it should go into gear, then work it back and forth. Basocally you've created a small burr on the gear and you need to work it out.
If you want to validate this, a forum search should turn up numerous results of other people with the same issue and the solution above I just posted.
Again, I did the same thing - did a gear grind and had to do what I said above to fix it. 50,000 miles later and everything is still a-okay.
Old Mar 22, 2015 | 03:55 PM
AA56's Avatar
Took a little bit of force but it worked itself loose. I do notice a small grind going into sixth but I'm hopping for to get smoother with a little time.
Again thanks for the tip it works much better.
Old Mar 22, 2015 | 04:06 PM
notaloafer's Avatar
The small grind will work itself out over time. I've actually done it twice >< in my car. According to Billman on here, it's not a biggie. I was terrified when I first did it to mine!
Old Mar 23, 2015 | 03:04 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
WOT in 6th gear will help flatten the burrs on the 5-6 gear collar and cure it.
Top_down
Oct 31, 2018 03:42 PM
Giozilla
Jun 23, 2013 05:33 PM
Red97GST
Apr 23, 2012 11:36 AM
HondaGuy
May 5, 2001 02:51 AM
