Notchy first & second gear
Old Jun 3, 2011 | 07:47 AM
hyperkin's Avatar
Default Notchy first & second gear
So here are the situations,
First problem is the first gear, lets say at a complete stop i want the car to move, i put into first, and it is very notchy, i can feel a two steps engage, it is like you cant shift into first directly, you need to give it a bit time.
Then the problem for second gear is only when downshifting, when downshifting into second, it is alot more notchy than downshift into 3 4 or 5?
all the fluids(tranny, diff, clutch) are fresh, the car has 17k miles, all these problems are there since i got the car, and it is not notchy when 1>2 or 2>3.
Just wanna know did anyone experienced anything similar on their S??
Old Jun 3, 2011 | 07:50 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Very likely rusted input spline on transmission.
Old Jun 3, 2011 | 12:00 PM
hyperkin's Avatar
thanks for the reply, but how complicate it is to change that part? how come it is rusted so fast in like 2 yrs?!
Old Jun 4, 2011 | 04:39 AM
CorneringMachine's Avatar
was it cold? the weather? maybe tranny is cold and needs to warm up a lil. Thought this was normal
Old Jun 4, 2011 | 05:49 AM
hyperkin's Avatar
its basically all the time, maybe it got better once in a while, but still happens 80%+ of the time. cant figure out whats wrong
Old Jun 4, 2011 | 06:58 AM
Billman250's Avatar
Top Answer: 1
you would need to remove the transmission to clean the spline. At that point i would do a clutch. how many miles?
Old Jun 4, 2011 | 09:12 AM
hyperkin's Avatar
just 17k miles, clutch is not slip, everything else is perfect of the car, it just really notchy, no grinding or anything.
Old Jun 4, 2011 | 01:52 PM
MBHs2k's Avatar
Mine has similar tendencies. Try changing the tranny fluid, use a synthetic oik see if that helps. These trannys can be notchy at times. Seems to be pretty normal.
dogzilla
Jul 6, 2008 03:39 PM
VTECturbo04
Jan 19, 2006 12:20 PM
FormerH22a4
Jun 11, 2003 04:11 PM
DWynne
Apr 19, 2003 07:58 PM
98TypeR#21
Nov 18, 2000 06:53 PM
