o2 sensor
Old Sep 23, 2007 | 11:46 AM
jah's Avatar
jah
Default o2 sensor
where are you guys buying O2 sensors?
my 5-wire as a direct fit is $330. i would consider a universal crimp on but want it to an exact functional replacement.
Old Sep 23, 2007 | 12:31 PM
duanet85's Avatar
do you mean primary or secondary o2 sensor?
Old Sep 23, 2007 | 12:46 PM
jah's Avatar
jah
thanks
primary... before cat
Old Sep 23, 2007 | 01:24 PM
CKit's Avatar
There are plug and play replacements (non-OEM, but same company) for <$100.
Old Sep 23, 2007 | 01:42 PM
duanet85's Avatar
did you mess it up putting a header on or something? how did it get busted? i cross threaded mine when i put it in my aftermarket header. in the mean time i bought a used one from a member on the board its off an 03 with approx 21xxx miles. i paid 115 shipped...if ur interested lemme know. i never used it, got my header and the o2 sensor fixed at a machine shop.
Old Sep 23, 2007 | 05:34 PM
jah's Avatar
jah
i am a little hesitant in buying a generic unit and crimping it on because of the application (its a honda, none s2000 tho)
what vendor to use to reduce costing?
Old Sep 23, 2007 | 06:26 PM
iam7head's Avatar
most of the newer honda will not take universal unit without throwing codes, code 41 to be the most common code even the wire and soldering is done perfectly.
can't really fix it, don't even try the bosch unit.
s2000maniac
Mar 29, 2025 09:09 AM
Subalahoo
Apr 6, 2009 02:48 PM
SpaYellowS2k
Jun 28, 2008 06:57 PM
Black Sheep
May 4, 2006 04:12 PM
thetz99
Nov 21, 2005 04:16 AM
