O2 sensor bung on Amuse R1000
Old May 20, 2004 | 05:29 AM
mxt_77's Avatar
Default O2 sensor bung on Amuse R1000
Since the Amuse R1000 is a header-back exhaust, does anyone know if it has a bung for a secondary O2 sensor?
Old May 20, 2004 | 10:57 AM
Gernby's Avatar
Former Sponsor
Would you want it to have a bung? My secondary O2 is just tie wrapped to the transmission.
Old May 20, 2004 | 12:11 PM
mxt_77's Avatar
I thought that even with the o2 Sim, the o2 sensor needed to be in the exhaust stream, so the numbers make sense to the ECU (in other words, they would just be "pretty-fied" versions of the real emissions value). Does the o2 Sim just send a pre-set value all of the time? I guess I don't understand how o2 sims work.
Old May 20, 2004 | 12:15 PM
Gernby's Avatar
Former Sponsor
The ECG simulator creates a fake O2 signal to spoof the ECU. It reads a couple of the ECU inputs as well (TPS, MAP, etc.), so that it can create a realistic signal. The only reason why you need to keep the O2 wired up is to load the ECU's heater circuit.
Old May 20, 2004 | 12:28 PM
mxt_77's Avatar
Gotcha. Good to know.
Thanks for the info... and with that, I don't need to know if the R1000 has an o2 bung (which I doubt it did anyway).
cdelena
Jan 23, 2016 08:34 PM
Chuck S
Dec 8, 2015 06:37 AM
vadhert
Apr 26, 2009 09:13 AM
roku
Apr 9, 2008 11:01 AM
OC_
May 28, 2006 08:24 AM
