Odd AC issue 2007 AP2, help request
Old Jun 23, 2015 | 12:08 AM
OICU812's Avatar
In regards to comment about "thermal protection switch". If I've proven power to the AC clutch and no go when (hot),but fine when all cooled off how can it not be anything other then the clutch internals failing? Should I also source a TP switch as well to be safe when replacing these bits?
Old Jun 23, 2015 | 07:06 AM
windhund116's Avatar
Dunno. I presume the thermal protection switch is some type of thermocouple unit. These things have failed or not worked properly on other devices.
Just a thought. You prolly can test it with a volt meter, while heating the device.
Old Jun 24, 2015 | 07:31 AM
rossco's Avatar
A/c clutch relays go bad. If doesnt turn on. No power will get to compressor. Fast easy check is to swap relay with horn relay. They are the same.
Old Jun 24, 2015 | 07:36 AM
OICU812's Avatar
Rossco tested direct power to clutch when everything in engine bay was hot and no click so that bypassed the relay all together.
W0Pdego
May 28, 2020 12:30 AM
FastUnicorn
Nov 7, 2018 12:08 PM
s02k
Jun 24, 2011 10:39 AM
jlicup
Mar 2, 2011 02:41 PM
BahrainONE1
Jul 24, 2009 11:59 AM
