odd vibration
Old Sep 12, 2006 | 09:24 AM
Johnny Sack's Avatar
do you think this problem can be solved simply by adding half shaft spacers? or is the damage done?
Old Sep 12, 2006 | 09:46 AM
djpeak10's Avatar
yeah once the damage is done it is done. reportedly putting in the spacers just stops future damage.
Old Sep 12, 2006 | 09:49 AM
smyroad's Avatar
Originally Posted by djpeak10,Sep 11 2006, 01:53 PM
and your hub nuts only need retourquing when you hear that clicking noise but that wont solve your problem you described
Good point, the vibration means something is damaged (CV's most likely)
Old Sep 12, 2006 | 10:00 AM
since i am booked for the next 6 weekends with honey do's and other non-FUN(S2K) related stuff, i might just pick up some spacers since it just started yesterday and see if i can hold it off until i have a sat to put my stock springs in.
Old Sep 13, 2006 | 08:30 AM
i did some searching, i am thinking that if i get the spacers and do a diff fluid change might solve the problem for now.
Old Sep 13, 2006 | 11:35 AM
djpeak10's Avatar
i dont think so but you can give it a try, I know some buddies with the spacers and they claim little to no noticable difference
Old Sep 13, 2006 | 12:36 PM
so i do have weaker joints. there has to be thousands of lowered s2ks and i have found very little info on this from the forum?
Old Sep 13, 2006 | 01:12 PM
djpeak10's Avatar
Here is the bottom line, all S2000 have weak inner cv joints that is why they have a tsb for it, however when you lower the car it seems to wear them out even faster. So if you were to install the spacer today you would keep the cvs the way they are, whats done is done. what i would do if I were you is take springs out, go to dealer have them do tsb then put springs back in followed by the spacer kit and you shouldnt have a problem.
Side note I use to be all freaked out about this problem as well but over time i realized that it is very very common on our cars.
Old Sep 13, 2006 | 01:37 PM
as you can see i not taking the news so well!
G Rahn
Sep 9, 2011 01:32 AM
Bandit_287
Mar 20, 2011 09:07 AM
josh7owens
Jan 19, 2011 10:22 AM
Afty
Aug 12, 2010 02:21 AM
HondaS
Jul 24, 2007 11:10 PM
