OEM ECU
Old Aug 29, 2012 | 07:44 AM
f20kills's Avatar
Default OEM ECU
As the topic states.
I was wondering if I can remove my current ECU and have my other OEM ECU programmed on the same key.
This way I can swap them out on the dyno.
It would make sense that I can but I wasnt sure if they "imobilize" the old ECU
Old Aug 29, 2012 | 07:49 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
ECU immobi code is part of the hardware parts of the ECU. You cannot change it.
You will need a key for each ecu.
Old Aug 29, 2012 | 08:10 AM
f20kills's Avatar
But you can replace ECUs so they must disable the old ECU then according to your answer.
My current ECU (04)is not the factory one and ueses my original key (02).
Old Aug 29, 2012 | 08:26 AM
s2klariat's Avatar
They do not "disable" the old ECU. The key is programmed to the ECU. Not the other way around.
Old Aug 30, 2012 | 03:37 PM
Slows2k's Avatar
As of 2010, The same key can be registered to more than 1 PCM. It still needs to be done at a dealer. You would install the new PCM, register the keys, reinstall the original. As long as the 1st PCM registered keys are not deleted the same key would start in both. It is entirely possible that this is no longer true with current Honda HDS software.
chirayufun
May 3, 2018 02:37 PM
gios2k
Jan 29, 2012 09:56 AM
bjjs2k
May 5, 2010 02:41 PM
robrob
Apr 26, 2009 06:32 PM
APEXSEAL
Jun 1, 2006 05:09 AM
