using another oem ecu on my car..
Old May 4, 2010 | 10:35 AM
bjjs2k's Avatar
Default using another oem ecu on my car..
Ok, from what i've read so far, to put another ecu on the car, i would need to take the ecu to the dealership and pay 150 or so? (i gues to reprogram the immobilizer..?) Is this my only option?
ie has anyone tested another ecu on their car without having to go to the dealership?
*if it matters, i'm testing if i'm having issues with my wiring harness or the ecu. my tps voltage seems to fluctuate up and down (.4% to .8% --> using an obd reader) even when its not connected to the sensor.
*i wouldn't be starting the car, i just have to turn the ignition on and look at the tps readings. Just not sure if it'll even go this far with a different ecu (without reprogramming).
HOpe someone can shed some light on this, thanks
Old May 4, 2010 | 03:37 PM
DFWs2k's Avatar
you can't borrow the person's key who you got the ecu from?
Old May 4, 2010 | 05:11 PM
Slows2k's Avatar
You need a non-immobilzer key that fits your car, and a immobilzer key from the donor car, tape them together, and start your car.
Old May 4, 2010 | 06:22 PM
downloader's Avatar
if its just for a test, try it out you might get a reading
Old May 5, 2010 | 09:53 AM
bjjs2k's Avatar
I originally thought something had to be programmed or what not, but i think i see what you're getting. So basically i tape the donor key to the donor ecu, then make a copy of my key so its not "immobilized?" and use that to start the car?
i think thats what you guys are saying right? lol THanks for the suggestion!
Old May 5, 2010 | 10:40 AM
deathsled's Avatar
If you don't plan to start the car you might be able to just turn the ignition to ON and test your TPS like you're thinking. The immobilizer disables the fuel pump but nothing else as far as I know. The engine will still turn over if you crank it but not fire up. I'd be willing to bet the sensors would be reading just fine, enough for you to test the TPS.
Old May 5, 2010 | 02:32 PM
Slows2k's Avatar
You must tape the immobilzer key to a non-immobilizer key that fits your car. You don't tape anything to the PCM. The key must me turned to on for your cars immobilzer receiver to read the donor key.
Old May 5, 2010 | 02:41 PM
bjjs2k's Avatar
this will be my first option, hopefully it will still activate the readings of the sensors, otherwise i'll do the tape the key method. thanks everyone for the suggestions.
f20kills
Aug 30, 2012 03:37 PM
yourboysoap
May 10, 2011 08:25 AM
vbb
Nov 27, 2009 11:22 AM
robrob
Apr 26, 2009 06:32 PM
APEXSEAL
Jun 1, 2006 05:09 AM
