OEM FLYWHEEL
Old Mar 15, 2007 | 08:18 AM
CaymanS2k's Avatar
Default OEM FLYWHEEL
1. How much does the stock flywheel weigh?
2. can it be lightened?
3 How much can be taken off? please let me know?
4.has anyone done this before?
5. What results have you seen?
Thanks
webster.me@gmail.com
Old Mar 15, 2007 | 09:11 AM
Incubus's Avatar
Would you shave your brake rotors for the purpose of making them lighter? Technically the flywheel is a wear item; we shave it when we get a new friction disc.
Old Mar 15, 2007 | 12:53 PM
cdelena's Avatar
The stock FW is relatively heavy at about 14lbs while aftermarket units are 8 - 10 lbs.
Obviously you can shave all you want off the stock unit but anything more than an light resurfacing is not recommended. Honda says not to do anythiing but replace.
A number of us have Toda or Comptech FW's that perform well allowing the engine to rev up and down slightly faster.
Old Mar 15, 2007 | 01:18 PM
its my beater's Avatar
I had a flywheel for a crx lightened. Take it to a machine shop and have them remove the big lip on the back of the flywheel.
Do not remove any material from the face of it.
Old Mar 15, 2007 | 03:23 PM
S2KPUDDYDAD's Avatar
The thing is balanced and turns at or over 9K RPM's DO NOT ALTER THIS PART OF YOUR CAR!!!! You could end up dead by decapitation. Buy a light flywheel if that is what you are looking for. That is the safe way
Breiter56
Dec 29, 2009 01:08 AM
conanius
Mar 25, 2008 06:44 PM
kfdon
Jul 2, 2006 07:10 AM
1qwks2k
Dec 20, 2004 02:21 PM
