Off centre steering wheel (1-2 degrees)
Originally Posted by FormerH22a4,May 29 2006, 10:40 PM
It is an alignment issue probably, tire pressure is even. Also was going about 140kms/h on the flattest and smoothest road and had a vibration on pretty much all four corners.
Originally Posted by Race Miata,May 29 2006, 10:54 PM
Shimmy usually comes from wheel/tire not alignment. I think that's a different issue or it could be some bad wear on 1 or more of your tires that results in both issues.
How about we get the whole story up front next time?
Just visually looking though, seems my right front has a bit more camber than my left front. --car was pulling a bit left, if wheel is centered--
Okay, got an alignment done, the settings were off from two weeks ago where I installed the coilovers. Now close to stock specs again. The car feel good again though.
However, the steering wheel is still 1-2 degrees off center. Center position, car will drift a bit to the left.
How can you adjust this, does a deal have to do it?
I called the dealer and they said there could be two ways to tweak this:
1) minorly adjust the tie rods
2) take off steering wheel and move one spline over.
I think the tie rod ajustment is easier and safer. thoughts?
Originally Posted by Slows2k,May 31 2006, 12:23 AM
1 spline on the steering wheel is much greater than 1-2 Degrees. They can recenter the wheel by adjusting the tie rod ends equally.
Wheel is at 0:05-0:08 when going straight, a minor tie rod tweak should take care of it.
You know mine did that once. I realized that in locking the steering wheel, I would be turning it an appreicable amount after I turned the engine off. After a few of these, my "center" was off by a couple of degrees like you mentioned. Alignment checked out perfect.
So I tried an experiment, where I left the key in the ignition (so it doens't lock the steering), and turned the wheel opposite the rotation the wheel was centered. Naturally the front wheels turned, but I felt something like a little "slip".
I started the car up and drove it. Voila! The center was now really on center. Not sure what to make of it, but I would guess the power steering motor must have had some kind of slip in it.
Bassem
Bassem
