oil cap question
Old May 28, 2004 | 03:26 PM
dayves2k's Avatar
Default oil cap question
I know oil cap...anyways I was wondering if I could use this cap that is used on a Vette and some other cars.......I dig the idea that it is exactly the type of oil I use.....so do domestic oil caps fit on Japanese cars?
Old May 28, 2004 | 04:01 PM
xviper's Avatar
I would suggest you examine the two side by side to be sure. Make sure the threads are the same pitch and depth and kind (metric). Make sure there is a similar kind of sealing ring built in to prevent leaks. If it looks close, then try it and see if it takes about as much effort to screw it in and to remove it. Then try it at idle and rev the engine a bit more while under the hood and see if you can detect any pressure leaking out (we have enough under valve cover pressure that this will be immediately obvious). Then, for your own peace of mind, continue to check it for removal strength after each time you drive it longer and longer distances. This is the only way you will tell for sure. Unless someone else here has actually used one of these for a while, I don't think anyone can just come out and tell you "yes".
Please let us know the outcome.
Old May 28, 2004 | 04:35 PM
dayves2k's Avatar
[QUOTE]Originally posted by xviper
Old May 28, 2004 | 04:38 PM
dayves2k's Avatar
before someone says this....I guess I could just find the sticker that is put on the cap in question and slap it on my OEM cap
Old May 28, 2004 | 04:39 PM
xviper's Avatar
I'll have to try some of that beer.
s2000maniac
Jun 26, 2013 11:13 PM
rocsix
Feb 15, 2010 12:49 PM
NFRs2000NYC
Jun 30, 2008 06:09 PM
sliimhashe
Jul 20, 2003 01:46 PM
SteveUCI
Aug 7, 2002 03:17 AM
