Oil Catch Can Installed-hoses Collapsing
I just installed the Cusco catch can
and noticed that more so the outake hose leading to the intake manifold collapses, not to the point where its completely collapsed though. The intake also collapses but not as much.
I hooked up my vaccum gauge and was pulling normal vacuum at idle-20 inches of vacuum.
Someone else had posted with the same problem but cant find the post.
My conclusion is that the braided hoses provided are too flexible. I will probably change the hoses to the normal black rubber hoses.
Originally Posted by SC_Highlander,Jul 21 2004, 09:48 PM
My catch can is not the cusco, but I'm using regular black fuel line with no problems.
I will be changing mine then...
I am going through this right now, I had bought some braided hose from Home Depot and it is collapsing at idle and inflates under boost and when the guys saw it at the shop they told me to get either fuel injection or oil cooler hose - it is black but much stiffer - I bought oil cooler hose by the foot at a Auto Zone for a buck a foot and will do the swap this weekend!
The same thing happened to my cusco catch can. The transparent hose supplied by cusco flattened from heat when I was on the track and started to make a sucking sound.
I think one of the reasons why it flattened for me was because it ran over part of the engine area where it gets quite hot. I have replaced it with a much longer or more solid black rubber line from OSH and route it around the engine area. I have not had any problems since.
But i went down to Autozone and fixed the problem...
