Oil Change?
Old May 12, 2001 | 09:05 PM
SenSpeed's Avatar
Hi guys, Im planning on changing my own oil and was just wondering if the car had to be level?
Old May 12, 2001 | 09:27 PM
S2WOOOW's Avatar
When draining it, the car should be either level or tilted slightly so the drain hole is down. When you check the level when you're adding the oil, the car should be level.
Old May 12, 2001 | 09:35 PM
SenSpeed's Avatar
Thanks...its ok to jack the car up from the front right?
Old May 13, 2001 | 03:52 AM
cmnsnse's Avatar
put it up on jack stands, level.
He said slightly
Old May 15, 2001 | 09:16 AM
joe_s2k's Avatar
I usually do the following when changing my oil every month.
1. Jack the car on the passenger side
2. Slide underneath and remove the drain plug
3. While it's draining, lower the car again so that its level.
4. Wait
5. Lather
6. Rinse
5. Repeat as necessary!
Old May 15, 2001 | 10:12 AM
SenSpeed's Avatar
anyone know the torque lb you need to tighten the oil filter?
Old May 15, 2001 | 12:27 PM
S2K Fan's Avatar
SenSpeed
Are you meeting up with us in San Marino this weekend?
Old May 16, 2001 | 02:25 AM
cmnsnse's Avatar
usually the filter will say something like 7/8 trun after gasket touches engine, kinda like the spark plugs.
Maybe the honda filters give the torque?
Old May 17, 2001 | 01:48 PM
WhataRide's Avatar
Can an effective oil change be done with the S2k up on ramps?
Old May 20, 2001 | 04:20 PM
Big Al's Avatar
The repair manual specifies 7/8 of a turn after the rubber seal touches or 16 lb-ft. The Honda replacement filters come with numbers around the circumference, 1 through 8, which allow you to count them off to get the 7/8 of a turn. Just did mine today and used the 7/8 turn method.
[Edited by Big Al on 05-20-2001 at 05:29 PM]
