Oil filter question
I have a Fumoto Valve as well, I use a shallow pan that I bought from WalMart a few years ago.
Hopkins FloTool 05080 Less Mess Oil Drain https://www.amazon.com/dp/B003KFX4NM/ref=cm_sw_r_cp_apa_i_fa1.Bb2TST4FA
and yes, breaking the torque on the oil filter, if you back it off ever so slightly, air seeps in breaking the hydraulic vacuum, allowing the oil to drain to the engine oil pan - out the drain into the drain pan.
rpg51 (12-01-2018)
It's the FloTool Less Mess Short Pan.
Hopkins FloTool 05080 Less Mess Oil Drain https://www.amazon.com/dp/B003KFX4NM..._fa1.Bb2TST4FA
Tip... try it a couple times before draining. So you can figure out how much to back it off to not spill out, but allow enough air in during a 10 minute "drain" time to break the vacuum. If you try and fail, start the car for a moment and then turn it off and do it again. Once you figure out how much to back it off(take note of the numbers to clock it) remember the amount of turns for next time. and go ahead drain..
Received 1,563 Likes
I use disposable aluminum pans (Costco) for oil changes. You get a couple dozen for about $10 or so. I do use them for cooking too (great for beans under roasting/smoking meat so the drippings flavor the baked beans) but I find half of them go for oil changes with the 5 cars I have/ kids have. I slide the aluminum pans (chafing dishes) on top of a big metal drip pan that is always under the cars (WalMart) to make it really easy to position and in case I slosh the aluminum pans too much and spill. I drain the oil into used 5qt oil containers (5qt Mobil 1 from Wal Mart for $24) for recycling and then just put the used pans in a large bag (usually the 40 lb dog food plastic bags or 50lb chicken food bags) so nothing drips out and toss them in the trash. Super easy cleanup.
I now use a Fumoto valve on all my cars including my Jeep and Tacoma. You can drain just as much as you need or want. No worries if you overfill. You can also drain directly into quart bottles if you have the nipple version Fumoto. Just like bottling your own beer!
Can you guys move the car out from over the pans so you don't have to slide/slosh oil filled pan out from under the car. I've spilled oil doing that in my day.
The pans I use, pictured above, do not hit the car in any way. I can slide them around with impunity or I suppose I could drive on top of them but I don't have a reason to do that. I show them sliding from the side behind the front wheels but they fit equally well under the front too. My car is stock.
Maybe I have had more luck sliding the oil filled pan on top of the large drip pan. It makes it easy to slide without much jerking around that might spill the oil. You can see I have a carpeted garage floor and I have yet to wind up with any oil on it.
I am definitely going to try this out...
I already have that same undercar walmary pan, for the same use, but with your typical plastic drain pan. In case some spills off that. Wind during drain, bad aim, etc.
I spend too kuch time cleaning the plastic drain pan. Throw away sounds like a great idea.
Instead of recycling 5 quart oil jugs for the used oil, I use a purpose made jug I bought somewhere. Similar height to the 5 quart, but way wider and with a huge mouth. Heavier, plus wide, so it won't tip when empty and first trying to pour stuff in. Holds a lot of oil.
