oil level
Old Feb 6, 2009 | 11:38 AM
Ap2masta's Avatar
Default oil level
went to the dealer and they did my maintnence and when i went to check the oil it was half way between the H and the L on the dipstick is that ok? the dealer said it was perfect and it was fine. i checked it when the engine was cold
Old Feb 6, 2009 | 11:44 AM
aeonracer's Avatar
Anything between H and L is ok, refill as needed if you burn any oil.
Tjs S2k's Avatar
Thats fine, Even at the bottom of the dipstick its only 2 qts low. Your dealer was right, thats fine.
Old Feb 6, 2009 | 12:07 PM
Downgear's Avatar
I know from the bottom diamond to the top diamond its 1 quart. Do you mean the actual tip of the dipstick>?
Old Feb 6, 2009 | 12:42 PM
jyeung528's Avatar
you can check it after you drive and shut down the car for a couple minutes...it may be closer to the L, which is still fine, but would be a good time to top it off.
KonaMan
Mar 2, 2010 07:59 AM
timdon
Mar 4, 2009 10:28 AM
damsas
Feb 24, 2006 07:24 PM
SilverKnight
Sep 16, 2004 02:36 PM
DesertRat
Aug 25, 2002 02:29 PM
