Oil on lower support
Old Jul 7, 2011 | 07:58 PM
Importedpower's Avatar
Default Oil on lower support
I have a 2002 s2k, and i was changing my oil today and i noticed that there seemed to be alot of oil around the lower frame in front of the engine... basically from the passenger side motor mount around to halfway up down the middle of the support. Seems like there is a little spray across my oil filters, i have an oil pressure gauge, and i think it might be part of the issue, but seems like alot of oil...
Old Jul 8, 2011 | 05:20 AM
SgtB's Avatar
If it's a copperish colored liquid, it's probably the motor mount that has busted.
Old Jul 9, 2011 | 10:48 PM
ringo14's Avatar
get new motor mounts
Old Jul 11, 2011 | 05:36 AM
raymo19's Avatar
Check the T-connector for your sending units - today. Mine was brass and cracked where the threads go into the block. There were only a couple of threads still holding it.
I deleted the T and the sender for the idiot light and just use the sender for the gauge. It seems to be more accurate now as well.
Old Jul 11, 2011 | 04:51 PM
I will get pictures posted up tonight of what im talking about. I doubt its my motor mounts however
Old Jul 11, 2011 | 06:44 PM
i believe this here be the culprit...
Here is the spots with oil on them...
Old Jul 12, 2011 | 05:04 AM
raymo19's Avatar
You're welcome.
Old Jul 12, 2011 | 07:02 AM
Originally Posted by raymo19
You're welcome.
so what did you do? im confused... nothing feels loose to me
Old Jul 12, 2011 | 07:24 AM
raymo19's Avatar
I backed the car out of the garage into bright sunlight and let the motor idle and looked around with a flashlight until I saw where the leak was. It's a real PITA to see in that area - but then again you're a lot younger than me and can probably see better. I'm betting the leak is at the block.
I couldn't tell from the pics but you do have two sending units connected to a brass T correct? And that one end doesn't look right somehow.
Oh - stay away from that rubber hose - it's a coolant line.
Good luck!
ChefJ
Jul 14, 2010 04:13 PM
stopmenot2002
Apr 14, 2008 06:12 PM
rm7boy
Aug 20, 2006 07:14 PM
LUVNMBRS
Mar 1, 2006 05:04 PM
