Oil Pan
Old Oct 18, 2008 | 12:12 PM
ROTFLMAO's Avatar
Default Oil Pan
How durable are our oil pans? I was changing the oil today and was stupid in loosening the drain bolt. Instead of turning it to remove the bolt, I was tightening it. Well, I don't think I've stripped it yet but just curious to know if I had done any damage. I would say, I must have tightened the bolt an additional 15 to 20 degrees. Did I do any damage? I looked at the threads and they look ok by the way.... Thanks for any info.
Old Oct 18, 2008 | 01:43 PM
teanza's Avatar
not 2 durable in the 'over-tightening' department , but if ur plug torqued back down to around 30ft.-lbs. & didn't keep spinning, u should be ok
edit: if u don't have a tq. wrench, 30 lbs. is not as tight as you may think, so be careful
~tina~
Old Oct 18, 2008 | 02:04 PM
RadioZero's Avatar
our oil pans are aluminum and the drain bolt is steel. the pan will strip before the bolt strips. as stated above, if you can tighten the bolt to 29-30 ft lbs then you're good to go.
Old Oct 18, 2008 | 04:57 PM
ROTFLMAO's Avatar
Thanks guys.
VonFear
Jan 24, 2016 06:22 PM
Shaney
Dec 16, 2014 02:19 AM
dmw16
Aug 19, 2006 11:54 AM
folex187
Jan 31, 2006 05:29 PM
S2KFanatic
May 25, 2002 08:13 PM
