Hi guys, Im new to the forum. I just picked up this s2000 and i dont have much history on the car. Now Id like to start by saying I'm no expert but I do tinker from time to time.
It is an 01' AP1. I have a Defi oil pressure guage and engine oil temp guage installed which was giving me a low oil pressure warning light on my last drive. I noticed that engine oil temp is getting quite hot and the check engine light came on so i shut the car down and parked it to try and find the issues before damages occur. The oil pressure on the guage was reading quite low and then coming back to normal back and forth intermittently, So i figured it was time to stop the car and do some checks and repairs.
First thing i did was check the engine oil level. Which seemed Ok
second thing i did was remove the defi guage from the equation just for piece of mind and try a new oem pressure sensor but its my understanding that once the oil light comes on its almost already too late and engine damages could have already occured. So i figured that the Defi guages might have saved me
then I decided its time to open the oil pan and check the pump check valve and spring which Ive attached some pics of.
Where is the oil squirter? I dont see it anywhere under there.
I made this tool to remove the crank pully bolt
going at this now...but its really hard to remove.
any advice? Does the pump check valve look scored to the point of replacement?
The small marks on there I cant even catch a finger nail in, they cant even been 0.0005" deep So I don't know what to make of this and thought it best to ask the forum experts
I used a heat gun on the pulley and then lots of freeze spray on the bolt, it then got loose with no effort at all.
Impact gun probably works too but I'm not sure if the crankshaft likes that.
the tensioner was just two bolts, I wasn't sure if there was preload that I needed to remove before removing the bolts. I guess not, I just removed the bolts, Where do I obtain a set clip for re assembly?
now im stumped that i've got the pump out, and checked the radial and axial clearances (which are all in tightest possible clearance spec.)
what can I check now?
I replaced the sensor
the Pump seems ok but I'm getting overheating.
am I correct in thinking either the oil was too low or the main bearings are out of spec?
