oil pressure reading at idle
there was and old thread I was looking to resuscitate but couldn't find it
but anyways was curios now w/ the heat what everyone's oil pressure is at idle with the now kicking summer temps.
Mine averages 20psi at idle. I have a fast reading sender so the numbers jump around from like 17 to 23.
I see 90psi all day long at VTEC and even below VTEC just to add...
CR doesn't effect oil pressure.
Temperature, oil weight, bearing clearance, oil pressure relief valve spring, idle speed, all effect the pressure reading.
20psi is pretty typical at idle. 90-120 at WOT
