Oil temp & pressure
Old Aug 18, 2001 | 08:48 AM
Big Al's Avatar
Default Oil temp & pressure
Has anyone found a good solution to installing oil temp and pressure guages yet?
Old Aug 18, 2001 | 05:26 PM
4373's Avatar
The Defi-Link System is the nicest I've seen for expansion of water temp. oil temp, oil pressure, analogue tach and boost if you have an SC. There are less expensive places to buy it than the link below but this is the best description of the overall system
http://www.defi-shop.com/defilink/usdflink...nk/defifrm.html
Old Aug 19, 2001 | 03:27 PM
CoralDoc's Avatar
Those are very nice guages Dave! Do you know if they can be easily mounted in our car? Perhaps on the A-pillar?
Old Aug 20, 2001 | 01:09 AM
4373's Avatar
It is a very nice system indeed and the A-pillar should not be a problem for you. I really like the way the controller hooks to all the sensors and then 1 wire chains together each gauge you add.
I've pretty much decided on the Mugen 5 point roll-cage over the hard-top next time I have some extra cash flow and it will cover my A-pillars. I'm not sure how I'm going to adapt this kit other than very carefully. Maybe bye, bye, radio for the oil temp, oil pressure and water temp and the tach up top on a center dash mount.
I need lower seats first to view the dash from a 2 - 3 inch lower seating position to make the final call. There is an RX-7 club with the control unit for $110. I want to get it and hook up all the sensors for now, gauges and placement can come later.
Frick26
Aug 3, 2017 12:09 PM
chrisesteban
Mar 3, 2006 02:29 AM
S2000_Europe
Jan 17, 2006 08:38 AM
Casas
Mar 28, 2003 09:40 AM
Big Al
Jan 18, 2001 01:21 PM
