is this ok?
Old Apr 5, 2007 | 10:23 AM
HunterR's Avatar
Default is this ok?
First im not a trackstar or a motorhead so mercy me...I'm Starting to mod my ap2 and ive decided that i want to take a direction in which the stock theme of the car will never be blemished i like small stuff things that change the whole look but if i didnt tell someone they couldnt figure it out.....I'm planning to use Mugen spacers to even the stock wheels with the fender would i need (15 mm or 25mm) and then i'm looking for good coilover (brand?)to adjust the ride heigth and eliminate the fender gap. Has this been done before and what negative effects would i need to expect? I'd really appreciate the help~thanks
Old Apr 5, 2007 | 01:08 PM
S2KPUDDYDAD's Avatar
Do some search work here, you will find a lot on lowering the car Wheel spacers??? I'm not shure about.
Old Apr 5, 2007 | 01:56 PM
blackout's Avatar
going with a slightly wider tire will accomplish the same thing. I put 225/245 stagger front to back on my AP! rims and it helped to fill it out a bit. Its only 10mm on either side but it helped a bit
Old Apr 5, 2007 | 02:11 PM
hatch4raceb16's Avatar
Actually wheel spacers DRASTICALLY change the whole appearance of the S2000. They make the stance on stock wheels amazing.
Old Apr 5, 2007 | 02:53 PM
nearwater4me's Avatar
^ Yes I agree.
But what about durability?
Premature wear on bearings?
I've heard rumors but can anyone confirm this?
I would also like to add some spacers to the front(in case I want BBK)
Dan
Old Apr 5, 2007 | 03:46 PM
jeggy's Avatar
i suggest you add a factory front lip and drop it 1". then throw on the comptech exhaust. take off the windsheild tape and debadge the car.
then have the paint swirls removed.
this will make your car cleaner then the pope outta a fresh shower.
Old Apr 6, 2007 | 11:24 AM
HunterR's Avatar
I have the oem front lip and i love it thanks alot guys i appreciate it
tony1118s2k
Feb 10, 2016 08:04 AM
nofearofdanger
Aug 22, 2012 05:43 PM
Deanbramer
Dec 22, 2011 02:41 PM
Moddiction
Jul 27, 2008 11:39 AM
rony
Dec 13, 2005 01:22 PM
