ok problems after ap2 swap?
Old Aug 20, 2011 | 08:49 PM
woodburn's Avatar
Default ok problems after ap2 swap?
OK, so i just swapped out my 2001 ap1 engine and trans for an ap2 engine an trans, started the car and everything is fine but the engine is idling at 2k rpm and the motor is getting really hot for some reason. Could it be a vaccum leak causing the engine to run lean and get hotter? Any help would be really great i just spent over 3500 on this swap and it really starting to piss me off..lol
Old Aug 21, 2011 | 07:10 AM
JUSTINTHECOASTIE's Avatar
Is your temp gauge showing temp rising? or its just hot under the hood? As far as idle check your throttle cable and position
Old Aug 21, 2011 | 09:25 AM
jh4db536's Avatar
Proper coolant bleeding?
Sent from my T-Mobile G2 using Tapatalk
Old Aug 21, 2011 | 01:45 PM
RacerXI's Avatar
I'd suspect a vacuum line on the high idle. Check around the intake manifold for a loose connection. You're going to need to define "getting hot" also. Is it hot to the touch or temp gauge too hot?
Old Aug 21, 2011 | 07:15 PM
woodburn's Avatar
ok , i found the problem it was the coolent not bleeding right and the throttle body spring need to be re set.
Old Aug 22, 2011 | 03:40 AM
Sweet!
Rostyslav_18
Mar 11, 2018 07:32 AM
zakazak
Oct 5, 2013 05:12 AM
killa_uk
Mar 12, 2012 03:43 AM
Bigpeters2k
Aug 17, 2011 09:22 AM
124Spider
May 1, 2006 03:25 PM
