Ok, SLIGHT vafc problem.
Old Mar 20, 2004 | 03:01 PM
redsound's Avatar
Default Ok, SLIGHT vafc problem.
last night my friend Jimmy installed my VAFC, we sodered (sp) all the connections, cleared out the settings that the previous owner had installed, set all the throttle positions, sensors, etc etc and saved them.
then we went to start the car, it fires up, then just dies out. No CEL or anything, but it wont stay started. so then we unhook the vafc to see if the car will start, BAM! fires up perfectly and still runs like a champ.
we pulled the cover back to re-check the connections and all of the connections were fine, nothing had slipped out.
what could the problem be? are there some (safe) settings i could use untill UL tunes it next week at the Spugen BBQ?
anyone experienced this before with the vafc?
any help would be tremendously appreciated.
Old Mar 20, 2004 | 05:17 PM
AusS2000's Avatar
Well something's wrong (I guess you already knew that).
If you set up the V-AFC with no values in the maps and VTEC set to 6000 in 5800 down then it is basically doing nothing.
Check to make sure the MAP connections are around the right way. Get them mixed up and you can expect a problem like this.
Make sure the sensor type is 06 06.
Old Mar 20, 2004 | 07:12 PM
SSS2k's Avatar
Check the ground also, when I had mine on my Integra with a bad ground it wouldnt start.
Old Mar 20, 2004 | 10:20 PM
redsound's Avatar
cool, i will check that
Old Mar 21, 2004 | 01:53 PM
03_AP1's Avatar
make sure the TPS settings are proper....and also that its set up for a 4 cyl engine, because I believe the default is for a 6 cyl
Old Mar 22, 2004 | 07:46 AM
redsound's Avatar
we're going to re-check everything this afternoon, i'll keep you all posted.
Old Mar 22, 2004 | 09:04 AM
Gernby's Avatar
Former Sponsor
If the car won't even idle, then the problem has nothing to do with TPS IN, RPM IN, or VTEC OUT. It can only be a bad unit, or a bad connection for power, ground, MAP IN, or MAP OUT. I'm not sure if VTM could be an issue, or not. The VAFC settings wouldn't have any effect on its ability to idle.
Old Mar 22, 2004 | 09:42 AM
redsound's Avatar
[QUOTE]Originally posted by gernby
Old Mar 22, 2004 | 10:00 AM
03_AP1's Avatar
if it doesn't even idle....then I would say most definately the 4 vs 6 cyl setting.
Old Mar 22, 2004 | 10:21 AM
jojipoji's Avatar
try the brown wire
