Over 100 reading on my oil pressure gauge
Certain times when driving, normally when the car is cold, I hit over 100 at 3k rmp's and up. After it warms up, you see it in the 80's and 90's which is normal from what I read. Idle's around 35-50. But I have noticed certain times, even when the car is warm, my oil pressure reading while driving will go to 110-120. Even today I hit 124 at one point. Do you think the oil pressure sender is bad or can our cars go that high? I read somewhere we have a pressure relief valve at 100psi but if thats the case, it doesn't seem to be working for me. Performance wise, my car seems fine.
Thanks
Thanks
My oil pressure reads as following:
Cold start: 80-90
Keeps dropping slowly til car is at operating temp until it finally reaches 35-40 at idle, 82-88 at 4k rpms 65mph on highway.
I have yet to see mine go into the 100s, so I would suspect something of that.
Even on a cold start, and if you immediately start driving, you should see 100s possibly, but not when warm. Oil thins out the more you drive, therefore, oil pressure drops.
For example, on a long drive, usually 30-45 minutes of highway, I usually see 23-27 psi at idle. That's normal considering the oil thins out with heat. And btw, this is 10w40, which is thicker than the average 5w30
Cold start: 80-90
Yea most of the time, its exactly like what you specified. But other times, like today, it goes over 100 off and on and it idles at 45-60. So in general it seems as though its off by 15-30 during those times. I have a spare oil pressure sender so I might just change that out since the gauge is new.
ROD
cheddaboy
12-06-2015 02:41 AM
Moddiction
07-08-2010 02:24 PM
Spoolin
05-16-2010 08:43 AM
