over reved
So today it track day and i was on my way to work and over reved. everything seems to be fine no vibe or clicking so i guess im going still. has anyone ever done this then a few days later had any problems or is it a "soon as it happens" kinda thing?
sounded like it reved to around 9200 to 9300
There was a post on here a while ago about how an individual bought a pre-owned S who's original owner over reved the car. The new owner put about 30k or so miles on it before the engine went down the pooper.
How did you over-rev?
I think different scenarios have more potential for damage.
For example, if you over-reved because you down shifted from 5-2 instead of 5-4, the transmissions inertia will force the engine to turn too fast.
If you simply rev too much inbetween shifts and didn't let the clutch out the car's rev-limiter will protect the engine for the most part.
did you overrev by shifting to too low of a gear? or did you just run the engine up past 9000?
if you did the latter, that's perfectly fine. there's a fuel cut at 92 or 9300 preventing the engine from revving higher.
if you overreved by shifting to too low of a gear, there's a possibility that the speed you were going and the gear you shifted to will force the engine to rev way past 9000 AND the fuel cut, thereby allowing you to reach rpms of over 10000 rpm by a mis-shift.
